For what it's worth:
Think ahead about everything you want to epoxy and get all parts test-fitted and ready. Have all your application tools ready. Then, mix your epoxy and work effeciently but quickly, don't stop to answer the phone.
So just plan ahead and get everything set as quickly as you can. Using this method, I don't even use 30 minute epoxy, unless it's something I need some time to carefully set up clamps, etc.
Seems it always goes farther than the amount I mix up, I always end up throwing out a scrap of cardboard with a scrap piece of balsa as a mixing stick hardened onto it, with more epoxy than what ended up on the airplane.
