ORIGINAL: rcpete347
HI all, I just received a Tams smoke pump and would like to verify normal opperation.
First to get the pump to turn off on aux 2, I have to set the travell to 150 and when it is off, I get a hum.
With the aux 2, I can get the two different pump speeds, but I am concerned about the pump hum in the off position.
Tams instructions say to set aux 2 at -100 and +100, but at those setting, the pump will not turn off.
Any advice will be appreciated.
Rcpete
You had to offset the off position.
This set up is litte tricky to set up.
