RE: !!!!!!!!!!!!!!please help me!!!!!!!!!!!!
nitro engines cant run backwards because the intake into the crankcase is controlled by a hole cut in the crankshaft, not a reed valve as in larger two stroke engines, so if run backwards the hole in the crank wont line up with the carbie to let fuel and air into the crankcase at the right moment.
