RCU Forums - View Single Post - electric drifting??
Old 06-29-2007 | 08:01 PM
peetiewonder's Avatar
peetiewonder
Default RE: electric drifting??
the reason that electrics are generally better for drifting is because 100percent of your torque is available at 0rpm, and the power is smooth and consistent, which give you predictable performance. Also i have heard that nitro engines do not generally do well in the low rpm/ high torque range for long periods of time, which is what drifting consists a lot of. Additionally electrics are hella quieter and cleaner.
The tt01 is a good starter car, but if you want something better i highly reccomend the hot bodies cyclone or cyclone s. or if u wanna go with shaft the tc4 is a good choice. As for a motor brushless is always the best but depending on your tire choice a good 17-23t motor will give u more than enough power.
