RCU Forums - View Single Post - Turbine life expectancy
Old 06-29-2007 | 10:11 PM
erbroens's Avatar
erbroens
Default RE: Turbine life expectancy
I bought a used P-80 for the DV8R we are using for flight control system research. It too is worth quite a bit more than the engine. Yes, you can get burned on a used engine, but in general, Enrique's arguments don't make sense. You can get a "lemon" right off the shelf just as easily as a used engine. The benefit of a used engine, as long as its been reasonably treated, is that the "infant mortailty" is already past and as likely as not, the engine will go fine for quite some time - this is especially true of the P-80's and P-120's which are over-built for their thrust ratings...
Following your logic, buying a new, unused turbine is a waste of money? Excuse me if I didn“t got your point.
Enrique
