RE: Mini Supersportster
Early airplanes such as the Write Flier and the Eindecker EIII used wing warping to generate roll effect. The idea you have is actually very old. However the tech used back then would not hold up to the airspeed requirements of todays aircraft. So you may want to do a little history work before you get started. Good luck and have fun with it.
