RCU Forums - View Single Post - DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
Old 06-30-2007 | 03:58 AM
merugo
Default DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
Friends,
After ten formulas and more than one thousand hits, TESTED DIESEL FUELS has been slightly reformatted, resumed and reported in this new thread DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES. The previous thread can be discontinued since you can find here its main results.
Some interesting diesel fuels proposed and discussed in various EVERYTHING DIESEL threads have been reported.
Some very original mixes are really tempting, so additional experiences and comments are needed.
Extensive experimental and field testing of oils gives space to improvenments and opinion sharing.
Additives are a broad range of products, of very different avaliability depending on type and country.
Ether or no ether opened the way to testing of low or no ether mixes...................
Everyone can report the formula he uses and its results. Keeping your report updated is welcomed since it enriches and actualizes the thread.
Non authors can add their experiences and/or comments to any reported formula by reediting and adding their views.
Characteristics/avaliability of fuel components can also be reported.
DIESELS WILL LIVE UNTIL THEY WILL BE FUELED!
Here I propose a simpler form for fuel report. Oils, combustibles and additives have a free form.
As a suggestion to fuel authors, please refer to your fuel No and/or name when quoting it in other threads, this will help newcomers.
Ugo
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR HIS/OTHER'S FORMULA by filling the blank form or reediting an existing one.
USE:
COPY; EDIT AND PUBLISH. YOU CAN ADD YOURS , DO NOT DELETE OTHER’S CONTRIBUTIONS
…………………………………………†¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â €¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦
DIESEL FUEL No: ............................ NAME: .......... .......,..........ORIGINAL DATE: ........
ORIGINAL REPORTER: ...................LAST EDITOR:..................LAST EDIT:................
FORMULA (in order of decreasing percentage of volume ):
1)-.........%.......
2)-.........%......
3)-.........%.....
4)-.........%.....
The way the mix it was obtained: .....
1)ENGINE:.............CARBURETOR: .... .. RUN TIME: .......STARTING: ............ USER:......
Comments:
2)ENGINE:.............CARBURETOR:.........RUN TIME: .......STARTING:.......... USER:.......
Comments:..
Reader's comments
Nickname : .................Comments:..
Other:..
