Had a friend loose a plane in the thick scrub next to our field 12 months ago,took 8 of us 3 hours to find the carcass.[
Started worry about loosing one of mine out there,did some searching and located these here in Australia
http://www.lakemunmorahhobbies.com.a...oducts_id=1989
And about a month ago I was really thankful for fitting it .[8D]
Was at the field early one morning prior to work on my own with my Spitfire,as you know covered in camouflage,when the wing failed during a loop and it spun in out in the middle of the scrub.[:-]
Simply headed out in the general area and the high pitched alarm lead me straight to it in a couple of minutes,I'm now fitting them to all my planes.
As you can see also helpful to remind you to turn off the plane if you forget
Cheers
