RE: DA 50 Possibly Overheating
Jake - use a prop no larger than a 21-22x8 till you get familiar with the engine .
A pink DA is an overheated DA--
proper air exit setup and correct nedle settings are easy on these if you simply avoid too much prop load and spend time learning how to set the needles - there is NO magic setting -except -once you go past two turns -the HS needle is effectively wide open.
