RCU Forums - View Single Post - epoxy curing time question
Old 06-30-2007 | 11:43 AM
scratchonly
Default RE: epoxy curing time question
Using cups makes the situation worse, along with high ambient temperatures. Mix it on a flat suface and gather it with your application tool as needed. To measure lay it in lines the same length and thickness. With this method you will quikly learn how much you need for a certain length of glue line. Works for me.
