RCU Forums - View Single Post - Bad luck with Magnum NX - Need help
Old 06-30-2007 | 02:39 PM
SOILWORK
Default RE: Bad luck with Magnum NX - Need help
Insulate the wires with heat shrink, you have to experiment with the placement of all the wiring. Like I said before servo glitching can be caused by the wires being to close to something electrical ar metal. Once you find a setup with no interference, secure the wires down so they dont move around when driving over rough terrain. This is a problem with a simple fix if it is your servo glitching.
