RCU Forums - View Single Post - Substitute for Ether
Old 06-30-2007 | 04:39 PM
  #866
Motorboy's Avatar
Motorboy
Default RE: Substitute for Ether
ORIGINAL: merugo
Andy,
where you speaking of :
"Renewablelube's website lists two versions of their two stroke oil. If I can get both, I'll test them in diesel and glow fuel."?
So no klotz benol, I guess. If these above are the oils, avoid them, they don't work with D I E S E L TWO STROKES.
Ugo.
Are you sure they don't work with D I E S E L TWO STROKES????? Can you tell us what the picture show us?
In early post you told you used the ZAHN viscosimeter and you wrote they was calibrated to a temperature since they are not in warm bath to keep exact temperature and the hole can not be changed. Can you explain how you did..
All measurements should be made at 77 F (25 C) are wrote in this link: http://home.fuse.net/clymer/water/viscosity.html
