RCU Forums - View Single Post - DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
Old 07-01-2007 | 08:08 AM
merugo
Default RE: DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
DIESEL FUEL No: ........05.............. NAME: .... Normand mix....ORIGINAL DATE: ... 1/25/07.....
ORIGINAL REPORTER: JMP_blackfoot...........LAST EDITOR:...merugo......LAST EDIT:.6/30/2007......
FORMULA (in order of decreasing percentage of volume ):
1)-......40%kerosene.......
2)-.......30%ether......
3)-.......28%castor oi.....
4)-.........2%ICI AVOCET ignition improver....
The way the mix it was obtained: ....straight mixing.
1)ENGINE: WEBRA WINNER 2.5cc CARBURETOR: .... .. RUN TIME: ..STARTING: ..
USER: JMP_blackfoot
Comments: starts and works well at low temperatures (0°C).
2)ENGINE:.............CARBURETOR:.........RUN TIME: .......STARTING:.......... USER:.......
Comments:..
Reader's comments
Nickname : ..merugo......Comments:.. Avocet is a mix of nitric esters apparently formulated for alchool diesel fuels, to be used with them from 5 % up to 8%
Other:..
