RE: Blade CX2 problem with 4-1 ...
sounds like your binding didn't work. Try that again and see if it makes any difference. Does the orange light on the reciver side (opposite the Red/Green side} light up and stay on?
Looking at the manual [link=http://www.e-fliterc.com/Products/Support.aspx?ProdID=EFLH1250]Found Here[/link]
To bind your RX to your TX:
•. In.order.to.bind.the.4-in-1.control.unit’s.receiver.to.the.transmitter,.yo u.must.first.insert.the.Bind.Plug.(included.
with.your.Blade™.CX2.and.replacement.4-in-1.control.units).into.the.“BAT”.opening.on.the .receiver ..Then.you.will.
need.to.power.on.the.4-in-1.control.unit.by.connecting.the.flight.battery.BE FORE.powering.the.transmitter.on .
•. When.you.connect.the.flight.battery.to.the.4-in-1.unit.with.the.bind.plug.inserted.into.the.“BAT ”.opening.on.the.
receiver,.you.will.see.an.orange.LED.blink.rapidly .on.the.receiver.itself .
•. Once.the.orange.LED.on.the.receiver.begins.to.blin k,.turn.on.the.transmitter ..The.transmitter.will.immediately.
enter.bind.mode ..Then,.once.the.orange.LED.on.the.receiver.and.th e.red.LED.on.the.transmitter.turn.solid,.the.
4-in-1.unit’s.receiver.is.bound.to.the.transmitter ..Now.you.will.need.to.power.down.the.4-in-1.control.unit.and.
transmitter,.and.remove.the.bind.plug.from.the.rec eiver .
Note: It is extremely important that you remove the bind plug from the receiver once it has been bound
to the transmitter. If you do not remove the bind plug, the receiver will enter bind mode every time the
-in-1 unit is powered on.
Sorry about the way the instrructions got all garbled there......... I copy pasted from a PDF file.......
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
