RCU Forums - View Single Post - paging the Real Dogman
Old 07-01-2007 | 05:04 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: paging the Real Dogman
Hey soilwork,
Its been awhile but if memory servs you wil turn your needles in about three full rotations, but start with 2full rotations. Due to your climate you may need to be turned in that far. Dont forget the low speed needle, in fact once you get the valve installed tune your engine normally.
Once you get it tuned let us know how the new valve works out for you, it might worth having this vavle made without the primer bulb..
Good Luck, and if you get hung up, you know where I can be reached..
