Ideas for New Shop
I tend to build a little higher surface that I can either stand and work at comfortably or sit on a stool. I have two that are 30 inches dep and one 36 inch. The 36 is a bit much and I don't think I will go that big the next time. Mayby so though, its the one I always end up working on. They are about 12 feet long each and shaped in a U. They are framed with 2X4s and the top is 1 inch Particle board from LP. I put poster board on top and tape in in position. Then if I get glue on it, I replace just the piece that needs replacing. I don't use pins so I don't worry about something they stick in.
