RE: 4* 60 question
A bolt set with blind nuts is not the same thing as a bolt set with LOCK nuts. Maybe a set of each is required? You know that the blind nuts and bolts are required, so it would probably be best to get that and then purchase additional hardware through your LHS like Bruce mentioned. I can't think of any place on the plane, except maybe the engine mount, where locknuts would be used.
