RE: myths
the reason that you can run the signal wire near the power wires for a servo is that the signal is much stronger in the servo leads then an antenna wire where the signal is very weak and it is amplified inside the reciever. the servo signal is a powered signal and is less suceptible to being influenced by the power wires
