RE: northstar help
I did a center of neutral check by hanging the plane level from a string attached from nose to tale,and the result is 14 inches from the trailing edge of the wing. Thats a 2 inch difference. I'm going to rebalance at 15 inches and see what I get in lead reduction from the nose. If it only a few oz I'll go with it as it felt realy nose heavy. I would like to thank every body that gave input as knowledge is power. Once again THANK YOU!!! Bart (man)
