RCU Forums - View Single Post - DX7 and BVM KingCat TitanSE flight report
Old 07-02-2007 | 05:21 PM
rcguy!'s Avatar
rcguy!
My Feedback: (69)
Default RE: DX7 and BVM KingCat TitanSE flight report
As promised here are some pics of the DX7 Spektrum install in my KingCat
Overall radio layout. Note dual charge/switch harness.
AR9000 mounted on a 1 1/2" balsa block to get it out of the same "plane" as the ECU. Spektrum monitor mounted on top. For $25 an absolute must to assure a healthy install.
Port remote RX with vertical antenna with a 24" extension. Antenna wires curl at the upper and lower skins.
Starboard remote RX slewed at 45 degrees with a 24" extension.
Hmmm... Just noticed it...I'll add some sleeves over the antenna wires on the slewed remote like I did on the AR9000.
Dave
ID:	715249   Click image for larger version
ID:	715250   Click image for larger version
ID:	715251   Click image for larger version
