RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 07-02-2007 | 07:37 PM
  #3653
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Arrow,
Harmonic Glitches:
What is Intermodulation Interference?
There are three basic categories of Intermodulation (IM) interference. They are receiver produced, transmitter produced, and "other" radiated IM. Transmitter produced IM is the result of one or more transmitters impressing a signal in the non-linear final output stage circuitry of another transmitter, usually via antenna coupling. The IM product frequency is then re-radiated from the transmitter's antenna. Receiver produced IM is the result of two or more transmitter signals mixing in a receiver RF amplifier or mixer stage when operating in a non-linear range.
"Other" radiated IM is the result of transmitter signals mixing in other non-linear junctions. These junctions are usually metallic, such as rusty bolts on a tower, dissimilar metallic junctions, or other non-linear metallic junctions in the area. IM products can also be caused by non-linearity in the transmission system such as antenna, transmission line, or connectors.
Harmonic Glitches are a reality and can be cause by metallic friction.
Just food for thought,
Dave / Choppersrule
ORIGINAL: ArrowNaughtic
Thanks D2......... this frame has brand new bearings in it. I will check that tho...maybe I recieved a bad one from the LHS. I have another 2 sets of mains and a set of tail bearings too......... I will try removing and replacing one at a time......... The LHS said yesterday to just buy another AR6000 for the DX6 and swap out. But it is funny that the glitching started in a new frame and with new bearings.......that BEARS looking into
The Futaba is going to the new plane I got for the GF, along with the servos that arrived today attached to the new unnamed belt driven tail blades heli I just recieved about 20 mins ago. Crash......... if you could when you get a chance....PM me, I have some questions on that 4ch TX/RX ESC combo you sent.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
