RCU Forums - View Single Post - Setting up Canards and ailerons on a rafale?
Old 07-03-2007 | 01:01 AM
extra 300
Default RE: Setting up Canards and ailerons on a rafale?
Edgar,
Thanks for your clarification. Please note that i do not have he manual you are referring to (is it the Tam manual?), therefore would appreciate if you can provide me with mixing rate for inflight setting. On the other hand presume the offset setup will also be active during take off view gear would be in down position i.e. offset mix activated.
Thanks for your clarifications.
Best regards.
Dany
