RE: Blade CX2 problem with 4-1 ...
Balance,
Thanks so much for going to that effort.
My CX2 just isn't having it though.
I have 3 bind plugs (1 for mine, 1 for my brother's, and 1 from my new 4 in 1)
All 3 failed to turn the 4 in 1's orange light on. I even went so far as to get a peice of wire (after trying all three and securing a direct connection between the 1st & 3rd pegs in the battery slot. No luck. Tried it on both of my 4 in 1 units too.
Other signs:
When I turn my brother's CX2 on, his servos auto adjust w/out the TX on. Whereas mine don't ofcourse. Only electronic activity is red & green lights.
I noticed that when I plug my servos into my brother's CX2 and power his unit on, the servos' don't auto adjust. When I plugged my servos' into his heli it turned orange the first time, then powering up again, HIS heli started to flash red & green like mine! Uh oh!
I quickly put everything back to normal on his and powered back up his heli w/ his TX and after blinking red & green for a little it turned orange again and all was working fine w/ his. I was afraid I screwed up his heli by connecting it with the servos from my CURSED CX2!!!
My unit is CURSED electronically.
Anyone have any energy to offer another solution?
I won't blame you if you don't!
