RCU Forums - View Single Post - Evo .46 was running funny this week.
Old 07-03-2007 | 09:27 AM
Montague
Default RE: Evo .46 was running funny this week.
I've no problem with that.
I do have a problem with you coming in and proclaiming that any engine that isn't your preferred brand is junk when the question wasn' t "what's a good engine" but instead was a simple question about weather changest causing the engine's mixture to change.
By ranting on about the engine, you gave the impression that the change experienced was due to some flaw in the engine, while it was clearly the change in the weather conditions. Even OS engines change mixture settings with weather changes. Your post was less than helpful and totally off the point of the question, which is why I responded as I did.
If you had written that same response to someone asking "what engine should I buy", my response to you would have been different.
