RE: SERVO EXTENSIONS
There are probably more failures due to using extensions than any other cause. Especially if the connection is hidden and not repeatedly plugged and unplugged to clean the corrosion off the connectors. If you are in a damp climate, this is even more possible. If you can, eliminate the extension by splicing in a longer length of wire as suggested above.
