RE: GST. Should I or Not?
Hey Darkfire, the gst is definitely NOT an entry level truck, so if you are that worried about it, then maybe you should consider something else,,,Wait,, did I say that?? Tell you what darkifre, I'm gonna out on a limb here, if you break something on your first run out I will help you fix it ok?? BUT, you have to take the time to break in the motor properly, you have to go completely thru the truck and check out everything carefully. You do that, and I will help you fix your truck if you break it on the first run. But if you do break it I will want many pictures to see exactly what is broke, so we can get you up and running...Deal???
