RE: DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
DIESEL FUEL No: ...........07............ NAME: ..Air fresh mix...ORIGINAL DATE: 04/29/07.
ORIGINAL REPORTER: ..merugo.....LAST EDITOR:..merugo....LAST EDIT:.7/3/2007......
FORMULA (in order of decreasing percentage of volume ):
1)-......40...%......kerosene.
2)-.......25..%......castor
3)-........17.5.%....turpentine (vegetal, NO mineral substitute)
4)-....... 17.5 %....ether
The way the mix it was obtained: .....straight mixing
1)ENGINE:.mars 2.5...CARBURETOR: ..fix .. RUN TIME: ..3h...STARTING: ..flip. USER:merugo.
Comments: It is based on a fifty years old italian mix. Strong mix without ignition improver. Interesting as showing the possibility of using terpenes in a mix.Nice pine scent...but if you like citrus scent substitute turpentine with lemonene technical grade ( paint solvent)
2)ENGINE:.............CARBURETOR:.........RUN TIME: .......STARTING:.......... USER:.......
Comments:..
Reader's comments
Nickname : .................Comments:..
Other:..
