RCU Forums - View Single Post - Published versus calculated thrust readings
Old 07-04-2007 | 02:41 PM
rmh's Avatar
rmh
Default RE: Published versus calculated thrust readings
Kitchen cynics OK?
I like your chart -good ballpark info
Where I see problems in getting best actual thrust reading -is that the airfame - cowl- prop proximity to cowl etc., all affect the "raw" prop data. Here is my "better " setup suggestion on getting good prop efficiency - move the prop as far as possible from any cowl points.
