RCU Forums - View Single Post - Need help with head speed. Please
Old 07-04-2007 | 02:58 PM
noguy's Avatar
noguy
Default RE: Need help with head speed. Please
MRASMM, can I ask you for a little extra help. I have everything input except all of the blade info. I just clicked the trex button and then changed the main rotor and tail rotor diameters to the stock specs of my mini titan. I dont know what all of the rotor parameters should be so left them as the trex specs. (figured it should be close)
As far as the rest of the fields: I have the batt, esc and motor all input correct. I also dont understand what the "tweaked, NoFudge, Vonmises, & Von+" buttons are supposed to represent. The page doesnt give any explanation.
Anyways,
Basically you want to figure out what is the ideal running speed and amp draw on your motor so that it is in it's peak efficiency and put that right in the center of where you fly your stick most of the time.
I'm a little confused about how to figure that out??? sorry if I'm being dense here but can you help. Thanks again, Noah
here is what I have: [link]http://dhrc.rchomepage.com/calcAdvanced.htm?kv=3000&voltage=14.8&pinion=10&ge arTeeth=140&drag=.85&MRdia2=711&mAh=2200&AUW=800&p ackV2=14.80&MRdia=711&TRdia=156&MRchord=30&TRchord =15&boomlength=420&TRratio=4.24&The_modtype=1&prof iledrage=0.0035&sliderThrottle=73.45&sliderPitch=3 .88&motortype=369&outKv=3000&outRm=0.023&MaxIo=25& outMotoroz=55&outIo=1.4&esctype=40&Resc=0.0045&Amp =35&metric_escWt=25.5&celltype=0&outCellCap=2200&n umofcells=4¶llel=1&Vcell=3.70&packV=14.80&outCell Res=0.009&outCellWt=&PackWt=239&metric_temper=12.1 5&metric_altit=1&metric_pressure=1013&AirDensity=1 .236909&temper=53.9&altit=3&pressure=29.9&govRPM=2 700&MRrpm=2700&Thr_P5=100&Thr_P4=85&Thr_P3=80&Pit_ P5=100&Pit_P4=75&Pit_P3=50&PitchRangeHigh=12&Pitch RangeLow=0&checkbox_mix=false&checkbox_gov=1&redBu tton=B-Save1&checkbox_bal_thrust=0&checkbox_bal_power=0&L astItem=MRthrust3&]Calculator prototype setup link 1[/link]
