RE: Black Magic v2 builder's thread! *Updated*
I tend to run more down elevator in my planes. For the same reasons Ryan does. When inverted you should be carrying a little down, so you need a little more throw to get the same results. Now, on my VF3 and the prototype I had a little less down elevator than I normally run to make the negative snap in masters cleaner, so to get the same feel, I added reverse expo, and made it more sensitive around neutral, and anyone who flies my stuff is probably thinking...I'm NUTS. I fly with basically Zero expo to start with. The VF3 is the first plane I've ever used any expo on.
Arch
