RCU Forums - View Single Post - What is safe voltage range for JR Tx
Old 07-04-2007 | 03:57 PM
da Rock
Default RE: What is safe voltage range for JR Tx
ORIGINAL: 763ersma27
I just bought a used JR Reciver and TX that shows a digital voltage meter. I was wondering what is a safe range, and what is the lowest voltage you would fly with.. Thanks
What does the manual suggest?
Most TX battery packs are 8-cell, 9.6volt packs. When they're fully charged, they'll show lots more than 9.6volts. After awhile they'll show right around 9.6volts. They'll show that for quite awhile. When they're about to run out of juice, they'll show 9.5 and below, and it'll be dropping.
Most RX battery packs are 4-cell, 4.8volt packs. Same as above except the voltages are around the 4.8 number.
You need to get an ESV for your flight packs. This is something you really should do. You need to learn to maintain your equipment as much or a little more than you need to learn to fly it.
Anything you question or that bothers you, just ask.
