RE: Skymaster F-18E issues!!!!!
How much travel do you have on your elevator?
How much flap are you using?
With the hornet you normally have to mix the flaps with elevators so when you deploy flaps the elevator should go up a bit to compensate for the nose going down.
In terms of CG it should be bewteen 130mm and 150mm, been 130mm the best point for getting the easiest landings.
Michel
