RCU Forums - View Single Post - Ailerons or Rudder
Old 07-05-2007 | 11:19 AM
Witterings
Default Ailerons or Rudder
Up until now I've only really used Ailerons and Elevator for turning my plane, is this generally the preferred method or should I start trying to get used to using the rudder (which seems totally alien at the moment) for normal turns - I realise you need to combine it for axial roles, knife edge / aerobatics etc ???? If I should be using the rudder in what situations is one preferred to the other and any tips for the best way to start trying to get used to the change.
Thanks in advance !!!!!!!!!!!!!
