RE: World models spot on 50
Yes, I have! It flyes very nicely. I can compare it to the Twister 50 and it flyes much better. Mine does knife-edge with no coupling, recovers nicely from Snaps when you release the sticks, during inverted flight you have to give it a little down to keep nose up, triangle loops and square loos are perfect.
On the other hand the landing gear is made out of aluminum and it is extremaly heavy. I would suggest to get a CF landing gear IF you like the airplane. The covering is questionable, some of decoration came off during flight. It is a very low heat material and it looks like when they covered the airplane they tried to use as less heat as possible and it can come off just by looking at it.
CANOPY: It does not releases from the fuse
