RCU Forums - View Single Post - Trex 600 Question: EPA and the Tail
Old 07-05-2007 | 03:52 PM
chattown
Default Trex 600 Question: EPA and the Tail
Hi,
I have Trex 600 with GY401/9252 with Futaba 6EXH for Heli.
Q1) I can't seem to find End point adjustment for the Rudder. I used the EPA settings for every other servos or max range of swing, but the rudder, only effect it has is the speed of the servo movement, not the range. I need to set the range so it won't bind at full push.
Q2) When it's up and hovering, it drifts counter clock wise slowly. The length of the tail cable and the settings are right, but it likes to drift. It's in AVCS and no matter what gain I get set, it just likes to drift.
Please help if you're Trex expert or Heli for that matter.
Thanks in advance.
