RE: Ailerons or Rudder
yea the rudder will turn the plane either way u want it, and as it turns the inner wing will be travelling less then the outer wing and this will create less lift on that side which wil make the plane bank in. and the more you bank the more the rudder will be turning into an elevator and will pitch the plane down so watch out for that at lower altitudes.
