-the basics-
the radio=transmitter,a basic set up is 4 channels,you can fly most planes with this.they go into as many as 14
flight pack=reciever,battery,and servos most all of them come with 4 servos.
if you don't have your radio, then when you buy one it will have a flight pack that comes with it that matches the channel of the transmitter.
a good place to check is your local hobby shop=LHS
or you can look on line at
www.towerhobbies.com to start
you can buy flight packs for individual planes if you have a transmitter but it has to match the freq.or channel of the transmitter to work.
a typical flight pack has a reciever,battery usually a 600mah,and 4 servos including the on off switch.
you then need to buy a crystal that matches the freq./channel.
no blowing head apart you have arrived at the best place to learn about RC your eyes might fall out from all the reading you can do
this is the place to find the answers to your questions for sure
