RCU Forums - View Single Post - Need help with head speed. Please
Old 07-06-2007 | 03:04 AM
mrasmm
Default RE: Need help with head speed. Please
hehe, yeah, you're welcome =) one of my lhs's is ok but fairly opinionated for the amount they know, but the other one never knows anything.
I do have one question about float chargers. I'm gona post it over in the battery section, so if you know something about that, wonder on over there and see if you know what I need =)
about the headspeed, as long as your past the crashing stange, and it sounds like you are, the higher headspeed isn't really a problem. Just take it slow and get used to it, and stand far enough away from it so that no matter what happens it's not gona hit you =) probably about 15' or so. You could also mess with your throttle curve and run it a bit slower for a while, and just check the motor temps because brushless over heat more easily under lower rpms.
good save on the 150t main gear =)
