RE: New CMP Cessna 182 .52 size
At first look I thought that it would be perfect! But as I got to that point, found that with just the stock pipe the angle(about 120 degree) the angle would be great. The cyl head is a bit outboard and the pipe points inward a bit and with just the stock pipe it points to far inward and can't screw the muffler on without cutting the pocket out. By adding another 120 degree pipe to the end before putting the muffler on you can adjust it in and then down right in the pocket and the muffler will stick out the bottom of the pocket about 1 -1 1/2" and look great! You'll see when you get to that point. OS part #72109600 or tower #LXCB00 is what we need.
Good luck!
