RCU Forums - View Single Post - Need help with head speed. Please
Old 07-06-2007 | 05:04 AM
noguy's Avatar
noguy
Default RE: Need help with head speed. Please
ORIGINAL: mrasmm
about the headspeed, as long as your past the crashing stange, and it sounds like you are, the higher headspeed isn't really a problem. Just take it slow and get used to it, and stand far enough away from it so that no matter what happens it's not gona hit you =) probably about 15' or so. You could also mess with your throttle curve and run it a bit slower for a while, and just check the motor temps because brushless over heat more easily under lower rpms.
good save on the 150t main gear =)
I fly pretty well for about a year of off and on flying. imo.. I am very comfy with ff & various turns, my orientation (right side up) is pretty solid. I can do loops & rolls no prob. fly/hover a little invert.
I dont know why Im so nervious about my HS. I am almost done with my setup and am hoping for first hover this weekend. Maybe its all of the vids I see online where the heli just takes off like a rocket and goes waaaayyy faster than what I am used to flying.
I think maybe I just need to grow a pair.
