RCU Forums - View Single Post - Reverse Rotation?
Old 03-08-2003 | 12:16 AM
Ross Kean's Avatar
Ross Kean
Default Reverse Rotation?
I just received a new Fuji-Robin 25cc 2 stroke gas engine (for free). This is a Japanese built utility engine used for trimmers and brush cutters. I was really pleased until I got the casing off and discovered that the power takeoff is on the opposite side compared to the flywheel. If I make a prop adapter for the flywheel side, the rotation direction will be opposite for a normal prop. If I use the power takeoff side, the engine would have to be mounted with the flywheel toward the firewall.
Any suggestions? I would really rather use standard props than pushers. Is there any reason why the engine shouldn't be mounted with the flywheel toward the firewall? Alternatively, how well would the engine run backwards - I realize I would have to play with the timing.
Ross
