Reverse Rotation?
The pull cord is on the flywheel side and the rotation is clockwise. As I mentioned, the work shaft is on the opposite side of the engine and this would work with a prop hub attached (correct rotation). The problem would be that the flywheel would be at the back of the engine. It has a walboro carb.
Ross
