Reverse Rotation?
you could probably bolt an alum plate to the crankcase and use spacers between it and the firewall, depends how the case is made i guess. main reason i use electronic ignition is to get rid of that big flywheel out front but i've never had a problem with the way the g23 is set up, it actually more sense.
