RE: checking CG on a alpha trainer
The others are absolutely correct. With a plane that has the fuel tank forward of the CG need to be balanced with the tank empty. This needs to be done because if you balance the plane with the tank full the plane will become incresingly tail heavy as fuel is burned off. Please remember this saying "A nose heavy plane flies poorly, a tail heavy plane usually flies just once."
Ken
