RE: Trex 600 Question: EPA and the Tail
Thank you Fitz21 & BarracudaHockey!!
I was able to change the limit, but it touches the hub at full right even with at lowest limit and the servo buzzes. Although, the other way, left has room left. Does this means that I have to adjust the cable to make the tail pully be more away from the hub when the tail servo is at 90 degree initialized? If I do that, would I not lose that 15 degree initialization?
Don't know.... help
