RE: checking CG on a alpha trainer
If the tank is mounted aft of the CG (a very rare occurrence) then you would balance with a full tank. With a tank located EXACTLY at the CG it can be done either way. In all cases follow the instructions in the manual assuming you have used stock locations for equipment.
