RE: Designed a Balsa DLG
Thanks for the reply's. I found the plan for the Allegro Lite and see what you mean by the extended sheeting, this will be an easy fix.
For a tail shaft I was going to try an old carbon graphite golf glub that a friend of mine gave me after somehow snapping the head off of it. It was a Snake Eyes driver. So I named the plane Snake Eyes.
I drew up a picuture of a wing with the trailing edge squared up to the fuse, would this be a better wing or not? I'm sure the difference in the wings will not make any difference in my flying, I'm not that good.
The surgery is Tuesday so the building starts on Wednesday, if the head is clear enough.
