RE: Servo Saver
To All,
Great replies! I think your right, I will take the sevo saver off and put a Z bend on the control rod. I can not change out the tail wheel as easy as it is hinged at the vertical spar and the wire pinned to the rudder (the setup suplied with the kit). Maybe I will look around for a bigger/softer tail wheel. After reading some of the replies I'm thinking the tail wheel does not take as much punishment as a nose wheel. I was never to comfortable knowing the only think keeping the rudder and servo conected was two tiny set screws. Thanks for your help.
Eddym
