RE: battery question
Some systems (very rare now) required a center tap on the battery. If you have a voltmeter, check to see if there is any voltage between the white and black lead. If not is is just as stated above, the manufacturer using the same wire spool for batteries leads as for servos. In either case, just ignore it and make no connections to the white wire.
