RE: Wheeeeeeee.......... Blade CP!
New problem. Anyone heard of this problem Cp Pro G90 Gyro Brushless motor 370 park 25Amp ESC All eflite Equipment.
Symptom. Main Motor Looses power after mid throttle and Quits until throttle is lowered to 0 Then same thing if you bring it back up. This is only in Head hold gyro mode. Adjust the Gain to standard rate mode on the TX and it runs normally. Except In idle up Bring the stick down for down blade pitch and the same thing occurs. Loss of main motor power and shut off. Gyro is New ESC is new Brushless motor has less than 10 hours run time cant't be the motor since it runs fine in standard rate mode. Too many Variables for me to figure it out.I don't know if its the 3 in 1 messing up or the ESC or the Gyro causing some glitch. One More symptom. The ESC doesn't want to go into programming mode unless the throttle is Moved left after putting it at full . Tested with another Transmitter Same thing.
Any body who has any experience with something like this a pm or post would be appreciated. Don't really wan't to send it to horrizon and be without it for god knows how long.
Happy Flying Fossoman
